Finishing Services
Hand Polishing
N/A
Applications
Enhanced cosmetic appearance
Smooth and glossy
Hand polishing is a manual process where the part is sanded, then buffed on a set of abrasive wheels or rouges to achieve the desired surface finish. This is a subtractive process that removes material in order to eliminate scratches and other imperfections.
Design considerations
  • Radiused corners and edges generally produce better results than sharp ones
  • Wall thicknesses less than 1.5mm do not hold up as well during polishing
  • Internal or hard to reach features (including threads) are difficult or impossible to polish
  • Very tight tolerances, reamed holes, and threads may need to be excluded from polishing
CNC vs Die Casting Qualification Scorecard
Quick Evaluation Tool for Process Selection Compare die casting and CNC machining to determine the best process for your prototyping or production requirements. CNC vs Die Casting Scorecard Score each category from 0–2 based on your part requirements. Category 0 (CNC) 1 (Neutral) 2 (Casting) Your Score Production Volume <1,000 1,000–5,000 >5,000 012 Target Lead […]
CNC machining involves far more than simply uploading a CAD model and cutting parts. Every part is shaped by the material, machine types, cutting tools, finishes, and design constraints that work together to determine cost, quality, and performance. To help engineers better understand these relationships, the Fictiv team created the CNC Periodic Table of Elements—a […]
